TwinTurbo.NET: Nissan 300ZX forum - you light issue sounds like an earthing problem...
Subject you light issue sounds like an earthing problem...
Posted by Medallion Man on June 17, 2013 at 5:15 AM
  This message has been viewed 301 times.
In Reply To I labeled them all with sharpie when I took them off posted by youngbloodz on June 16, 2013 at 09:36 PM
Message most likely fuse/s blown, check your fuse box (all three) and earths.
I would be taking all the harness' off and redoing them.
but first try the timing again, tie the clamp open on the pickup and place it behind the #1 coilpack and try it that way.. also make sure the white line on the pulley is clearly visible.
can I assume you did the timing belt and checked that the pulley did line up right and counted cogs.
it sounds like the timing is way out to me.
good luck.
